Ideal Balun( Cadence analoglib)
hrkhari
Full Member level 4
balun cadence
Hi guys:
If I use the ideal_balun in analoglib, at a low input frequency of ten's of MHz the differential output signal seems to be in phase whereas if I use an input frequency of GHz the output seems to be differential, I had attached the configuration used. Does this mean balun could not be utilized for low frequency input. Pls feedback on this inquiry. Thanks in advance
Rgds
Radu Adrian
balun cadence
L0 and L1 are too small (10nH) and their reactance are almost zero at several MHz. These reactances are "in series" with internal resistances of V1 and V4 wich are probably zero. This is the reason why, at low frequencies, the two outputs of the balun can considered to be shortcircuited to ground and the output signals are very weak and "in phase".
