i need to fit tracks width with pads width in the connections.
black_flowers
Junior Member level 2
hi there, i'm having trouble with some tracks in altium designer. Those ones which are more wide than normal, are very close to the other pads because of its wideness. This is my pcb:
and the problem is because netP1_5 is too close to pads 1 and 3 in Q1 component.
I tryed creating teardrops but it seems to only work when tracks are thicker than pads and my case is just the opposite, since tracks are wider than pads.
is there a way to solve that problem?
You could route at both layers from Q1 to R2 with half of that width.
NetP1_5 could br routed from R2 to other points with actual required size.
yes, but i would prefer to reduce the with of the track just in the connection with the Q1 pad if it could be possible. I will solve the problem of the track width by pouring more tin in the connection.
