I have a bunch of diodes of the SMD type packaged in tape and I believe they are more than 500. As far as I remember, they were ordered by a mistake so I put them aside. They were kept in an anti-static plastic bag without any markings, PNs, or anything else that could help in identifying them.
As you can see in the following photos, they look like a Schottky or normal signal diode and the voltage drop across it is 0.550V.
Now, I was wondering if I can use this type of diode in a full-wave bridge rectifier circuit to rectify 220V mains. This way, I can utilize them for something useful.
They are MELF packaged but the only other identifying characteristic is the color of the cathode band. If it is silver it is probably an LL4007 which is a standard recovery diode rated at 1KV/1A. I have identical ones here. Use at you own risk though, there might be other devices with the same marking.
Hello e-music,
Schottky diodes normally have a lower voltage drop across them to what you've indicated.
I think Brian is correct in regards to them being general purpose rectifying types.
If you can, get a transformer with a low secondary output and make a full bridge rectifier
circuit and see how the diodes will tolerate it over time.
Connecting them directly to mains I would personally avoid, due to the fact that if they are
the Schottky type, I doubt they could withstand the peak reverse voltages generated by
direct AC mains connection. They would still work OK at lower AC voltage, but they will
heat up more than GP type diodes, as well as introduce extra noise due to their faster
switching speeds.
They definitely don't look like small signal diodes, and very doubtful they will be Zeners.
Regards,
Relayer
Red LEDs? Well, it could be difficult to identify them, but I'm pretty sure they are anything but "Red LEDs"! I have never seen a Red LED without a lens and packaged in such a way! )
Anyways, thanks for the info!
@Brian:
Thank you. Yes, the band is in silver.
@Relayer:
Hi Relayer,
Thank you very much for the input. A detailed and very helpful one, as usual!
Yes, and I believe they are GP rectifiers, too. I believe the only way to verify is to build a full-wave bridge and check them in circuit for some time. I'm working on a project that needs power directly off the mains and a Transformer-less PS is the only way for me to keep size and cost low for the board. I thought I could use them for the bridge-rectifier and save a little. Otherwise, a bridge rectifier in a single package is much better.
Thanks again!
@schmitt trigger:
Thank you for your reply. Yes, I had that in mind initially. I wanted to use them in a bridge rectifier configuration to rectify 220v/50Hz mains.
In fact, it's about 700 of them, not four. And I need to populate a big batch of boards I plan to build with these diodes. Nevertheless, I agree with you. Even $70 is not a big deal to order the correct diodes for my circuit.
By the way, the schematic in the photo has nothing to do with this circuit or the diode concerned!
I am just astounded. You are apparently building something to actually sell to customers, and you seriously considered building them out of parts that you DON'T KNOW WHAT THEY ARE? I hope you have good liability insurance.
Not at all! I will never think about it and if you noticed, I did mention that "even $70 is not a big investment to get the CORRECT DIODES" in my last reply. On the other hand, I used to build a handful of boards for testing before proceeding to mass production!
