i got error after debugging on lpc 2129 board using Keil uv 3(v3.62)+H-JTAG(0.60)+RDI
haroon_tech
Member level 2
bangalore
hi
i am using lpc 2129 board using Keil uv 3(v3.62)+H-JTAG(0.60)in Auto download+RDI Interface driver .. i got the following errors after debugging in keil
Load "C:\\Documents and Settings\\viji\\Desktop\\EXAMPLE PROGRAMS\\MCB2100\\Blinky\\Blinky.AXF"
*** Restricted Version with 32768 Byte Code Size Limit
*** Currently used: 892 Bytes (2%)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000108)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x0000010C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000110)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000114)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000116)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000118)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x0000011C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000120)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000124)
H-JTAG - H-Flasher - H-Flasher is busy or not ready. Please try again later.
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000000)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000004)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000008)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x0000000C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000010)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000014)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000018)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x0000001C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000020)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000024)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000028)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x0000002C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x00000030)
U $
*** error 122: AGDI: memory read failed (0x00000030)
*** error 122: AGDI: memory read failed (0x00000124)
Include "C:\\Documents and Settings\\viji\\Desktop\\EXAMPLE PROGRAMS\\MCB2100\\Blinky\\RAM.ini"
FUNC void setup (void) {
// <o> Program Entry Point
PC = 0x40000000;
LOAD Blinky.axf INCREMENTAL // Download
*** error 122, line 5: AGDI: memory read failed (0x00000014)
setup(); // Setup for Running
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000000)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000004)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000008)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x4000000C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000010)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000014)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000018)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x4000001C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000020)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000024)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000028)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x4000002C)
H-Flasher - H-Flasher is busy or not ready. Please try again later. (Addr:=0x40000030)
*** error 122, line 6: AGDI: memory read failed (0x40000030)
g,main
*** AGDI-Error: can't setup break at 0x00000284
please reply.......to over come this error..........
thank you
