do_rin_entertainment
Newbie level 5
I have a problem: I am trying to build some pcb drawing facility which i can control via the lpt port of my computer. the problem is that the stepping motors work with 24 volt and the output after the SN74C374 is no more than 2.2 V (each SN recieves the 8 data-out pins and one of the 4 clock-out pin and makes a 32 instrad of 8 data bits output)
I really need some help so if someone has the knowledge I need or has some links... well then please help me. :?
I also need some controllers for the steppers: I do not know any code of them but I know what they should have as an output:
1st controller:
To be able to drive the engine in half- and full-step mode, counter- and clockwise, to be able to maintain the engine in current if there is no signal for stepping one more time.
I need it to have the following pin-ins:
pin_1 value: (it is a swich)
1: turn the stepper clockwise
0: turn the stepper counterclockwise
pin_2 value: (it is a swich)
1: half-step mode
0: full-step mode
pin_3 value: (it is a trigger)
1: turn the engine one step in the desired direction and the desired mode (if the trigger is hold down it shall turn the engine only once, not until it is released)
0: do nothing
pin_4 value: (it is a swich)
1: accept input commands from all the other pin-ins and if pin_3 is 0 the stepper shall recieve current in the position it is
2: accept inputs from pin_1 and pin_2 for selecting modes but not from pin_3 and shall not give the motor current (if the controller gives the stepper motor curent all the time, wheather pin_3 is 1 or 0 I can substitute this pin with a moc3041 which I connect to the ground wires of the stepper and if the gate is closed (if it recieves 1) then the gnd signal shall pass but if the signal is 0 the stepper shall be off-line)
here is a full-step graphic:
wire a1 GND it is 1 all the time
wire a2 1 0 0 0
wire a3 0 1 0 0
wire b1 0 0 1 0
wire b2 0 0 0 1
wire b3 GND it is 1 all the time
here is a half-step graphic:
wire a2 1 1 0 0 0 0 0 1
wire a3 0 1 1 1 0 0 0 0
wire b1 0 0 0 1 1 1 0 0
wire b2 0 0 0 0 0 1 1 1
:idea: I have quite an idea for a version but it needs machine-code programming and I don't know. There shall be an double-linked circular tail that shall have the half-step gates values (8 values), an pointer to one of them and when the triger is 1 then it shall enabl output and go to the next/previous 1/2 level (depending on pin_1 and pin_2 inputs).
:idea: :idea: OR an other idea: a controller that has only 3 pin-ins but keeps the engine in current all the time, on the position the pointer is; the pin-ins are:
the direction selector: (it shall be held down - 1 - for cw and released - 0 - for ccw)
the half-step trigger: 1 for acting and 0 for standing-by (it shall wayt for the trigger to be released and pressed again for moving the motor an other step)
the full-step trigger: 1 for acting and 0 for standing-by (it shall wayt for the trigger to be released and pressed again for moving the motor an other step)
an other controller I need is for the floppy-disk head-positioning stepper. this one needs the input as following:
full-step
phase 1 + -
phase 2 + -
phase 3 - +
phase 4 - +
half-step
phase 1 + -
phase 2 + - + -
phase 3 + -
phase 4 - + + -
phase 5 - +
phase 6 - + - +
phase 7 - +
phase 8 + - - +
this one is more complicated... i don't even have an idea on how to start.... hope anyone there knows...
hanks for reading this and please help me
1st controller:
1: half-step mode
0: full-step mode
0: do nothing
wire a2 1 0 0 0
wire a3 0 1 0 0
wire b1 0 0 1 0
wire b2 0 0 0 1
full-step
phase 1 + -
phase 2 + -
phase 3 - +
phase 4 - +
half-step
phase 1 + -
phase 2 + - + -
phase 3 + -
phase 4 - + + -
phase 5 - +
phase 6 - + - +
phase 7 - +
phase 8 + - - +
