HSpice- .MEASURE MIN for difference of two branch currents.
renz.bagaporo
Newbie level 3
Newbie level 3
Good day!
I am trying to know what ratio of W/L will give me the minimum current difference between the two branches of a current mirror. Here is my netlist:
VDD VDD 0 DC 3.3
R1 VDD 1 10
MNA 1 1 0 0 NCH L=LENGTH W=WN
MNB VDD 1 0 0 NCH L=LENGTH W=WN
.DC WN 0.4U 50U '(50U-1U)/10000'
.MEASURE DC WNSIZE MIN I(MNA)-I(MNB)
I hope to store the minimum difference between I(MNA) and I(MNB) in WNSIZE. However, in the .lis file, I keep getting the warning
"the measured variable for wnsize is not defined", and the output says
wnsize= 0.0000E+00 at= 4.0000E-07
from= 4.0000E-07 to= 4.9998E-05
which I am pretty sure is not the WN at which the current difference is minimum (I've checked the next values and I found an WN size at which the difference is even smaller).
What is the problem?
I'm not sure if such a measurement will work for a swept .DC analysis.
In any case, as the error message tells you
you must define your measurement result as parameter. Try:
.MEASURE DC WNSIZE=PAR('MIN I(MNA)-I(MNB)')
