strape81
Junior Member level 3
Hi forum users,
I try to figure out which is the right decision to make about the following case:
a microcontroller makes a measurement every minute. The data block (RealTime+meas_data) has a size of 8 bytes. These data are sent to an external memory. When the memory is full, then the old data will be overwritten. The desirable memory size is 1MByte.
As far as I know if I choose an EEPROM, I can read,write,overwrite or delete the data bytewise. In case that a flash memory is used, then I can read or write bytewise but overwrite or delete only sectorwise.
Did I understand their function correctly?
I am closer to 1MB EEPROM, what is your opinion?
