how would i decrease the frequency?
hysamir
Junior Member level 2
I am having my oscillator running at 100Mhz and i want some signal to be at 1Mhz
how would i go from 100 to 1?
flatulent
Advanced Member level 5
Middle Earth
You have two main choices. One is to use a digital divider. The other is to make a separate oscillator at the new frequency.
eecs4ever
Full Member level 3
Analog Environment
The Oscillation frequency is a function of the capacitance you have in your oscillator.
If you increase the capacitance in your oscillator,
does the frequency become lower?
jgarciarivera
Newbie level 5
The choices mentioned are good. Either used a frequency divider realized with J-K flip-flops or change the capacitor value of your oscillator.
avlsi
Member level 3
Yeah,its a good idea to use digital divider like divide by 4 circuit. It decreases error also,as you use digital.
yaxazaa
don't use two xtal unless you have to. Divided down is the best option
avinash
Full Member level 3
if it is compulsory to use 100MHz oscillator in your circuit,then you have only one option to use digital divider circuit using flipflops to get 1MHz frquency.but it will increase your chip area.so if not compulsory,you should go for new 1MHz oscillator.
vlsiattitude
Junior Member level 3
u can generate divide by 100 counter using synchronous counter. i think ripple counter may create problem at high frequency
