I read the pixel value of image in vhdl and segmented using threshold value.Now i want to verify it in matlab.I dont know how to do...please help...very urgent
You need to create a communication protocol, through UART/USB, to read/write data to your FPGA, start the FPGA calculation, read back the result and check it with your matlab.
Pleased, stop to said it is urgent, we usually never go to a forum if that is easy.
or u can do one thing save the output file in text format from any logic simulator and then read that text file in the matlab. den ur purpose will be solved.
