How to understand obfuscated IP codes?
Sumathigokul
Member level 1
Member level 1
HI,
Good day to all.
If suppose the HDL/ netlist code for FPGA design is obfuscated, how to understand it?? Is there any systematic procedure to perform it??
Thank you in advance.
Regards,
SUMATHI G.
Yes, you go to the company that you licensed it from, and pay for the unobfuscated version.
Better to design things from scratch, which would be less expensive compared to un-obfuscating or reverse engineering a design.
Unless you are doing your PhD thesis on it, what could possibly be the motivation?
Hi dpaul,
I am doing PhD in developing Obfuscation Metrics, so i am interested to know about it.
Then I guess you might be knowing more than anyone else here (unless some other forum member, who has already worked on it). Generally the big shot IP/Core provides keep the Obfuscation methods as a closely guarded secret. So even if an EDA board member has worked on it, I guess he/she will never share the knowledge here.
As I see it, your source of knowledge could be white-papers, IEEE papers or advanced text-books.
Obfuscation is a bit pointless now, given many EDA tools support properly encrypted IP. (i.e. IEEE P1735).
