willyboy19 said:There are at least two ways I am aware of to solve this issue:
1) Use a FET probe, which has only 1pF capacitive load on your SC amplifier output;
2) Add another wide band buffer with linearity much higher as your designed SC circuit. This may become very difficult if you already start with a high linearity SC circuit.
Thus, you may want to try 1). The FET probe is a little bit expensive, though.
