How to switch on a pulse amplifier?
lowell
Newbie level 5
Newbie level 5
sir;
This is my problem: I fed a signal between 0.4Volts to 0.6Volts to a 2N3906 Transistor. I could not switch on the amplifier. How would i deal with this?
The Frequency is 5MHz.
Thank you..
LOwell
0.4V-0.6V voltage is to low to switch on a transistor ..
Try to increase this control voltage to >1V and connect a current limiting resistor in the transistor's base (for 1V signal use 33Ω<R<100Ω) ..
Regards,
IanP
    lowell
This input signal is somewhat fixed because it is the output of the logic gates and will be fed to the said transistor..
Is it possible if we will put a comparator??
Usually, a logic gate output operate in wider range than 0.4-0.6V ..
But, if it is all you have you definitely need to amplify this signal and a comparator seems to be quite a good choice ..
Regards,
IanP
ok I will try..tanx..
Regards,
lowell
Added after 20 minutes:
sir:
do you have a design for a transistorized pulse amplifier..I had a hard time searching the net..
thank you
regards,
lowell
I certainly have one ..
Here is the link:
Regards,
IanP
i've seen the diagram. . .
is this a 5Mhz pulse?
This pulse amplifier should moretheless deal with 400ns pulses, but can you tell me who I am talking with: lowell or reggieboy ???
Regards,
IanP
we're a team. . . working together in a project. . . tnx 4 ur help. . . we really appreciate it. . .
