valxiao
specify setup violation
hi,guys,
i encounter a problem with gate-level simulation, run in modelsim,it appear the following :
r: ../../libs/modelsim_asic/fsc0g_d_sc.v(18445): $setup( negedge D &&& ~SEL:2841 ps, posedge CK:3 ns, 267 ps );
Time: 3 ns Iteration: 5 Instance: /../../../../../reg_coeff_data_reg_210_
clk in testbench: forever # 3 clk clk <= ~clk;(6ns)
clk in synthesis: set clk_period 4.8ns*0.9
set clk_skew 0.4ns
and report_max_path is: 0.006ns
why still have violation with $setup for reg_coeff_data_reg_210_? thanks!
in sdf:
(CELL
(CELLTYPE "QDFZCGD")
(INSTANCE ../../reg_coeff_data_reg_210_)
(DELAY
(ABSOLUTE
(IOPATH CK Q (0.381:0.381:0.381) (0.346:0.346:0.346))
(TIMINGCHECK
(WIDTH (posedge CK) (0.258:0.258:0.258))
(WIDTH (negedge CK) (0.620:0.620:0.620))
(SETUP (posedge D) (posedge CK) (0.276:0.282:0.282))
(SETUP (negedge D) (posedge CK) (0.261:0.267:0.267))
(HOLD (posedge D) (posedge CK) (-0.099:-0.103:-0.103))
(HOLD (negedge D) (posedge CK) (-0.037:-0.039:-0.039))
(SETUP (posedge TD) (posedge CK) (0.421:0.421:0.421))
(SETUP (negedge TD) (posedge CK) (0.817:0.817:0.817))
(HOLD (posedge TD) (posedge CK) (-0.192:-0.192:-0.192))
(HOLD (negedge TD) (posedge CK) (-0.155:-0.155:-0.155))
(SETUP (posedge SEL) (posedge CK) (0.783:0.783:0.783))
(SETUP (negedge SEL) (posedge CK) (0.353:0.353:0.353))
(HOLD (posedge SEL) (posedge CK) (-0.128:-0.128:-0.128))
(HOLD (negedge SEL) (posedge CK) (-0.034:-0.034:-0.034))
in stand-cell
module QDFZCGD(Q, D, TD, CK, SEL);
reg flag; // Notifier flag
output Q;
input D, CK, TD, SEL;
supply1 vcc;
wire d_CK, d_D, d_TD, d_SEL;
//Function Block
`protect
buf g3(Q, qt);
dffrsb_udp g2(qt, d1, d_CK, vcc, vcc, flag );
mux2_udp g4(d1, d_D, d_TD, d_SEL );
//Specify Block
specify
// Module Path Delay
(posedge CK *> (Q :1'bx)) = (10.68:16.82:30.00, 11.19:17.49:31.13);
// Setup and Hold Time
specparam setup_D_CK = 9.30;
specparam hold_D_CK = 0.00;
specparam setup_TD_CK = 10.30;
specparam hold_TD_CK = 0.00;
specparam setup_SEL_CK = 8.60;
specparam hold_SEL_CK = 0.00;
$setuphold(posedge CK, posedge D &&& ~SEL, 7.91:13.35:25.21, -2.94:-4.93:-8.41, flag,,,d_CK, d_D);
$setuphold(posedge CK, negedge D &&& ~SEL, 6.55:11.99:24.10, -1.46:-2.09:-2.87, flag,,,d_CK, d_D);
$setuphold(posedge CK, posedge TD &&& SEL, 10.87:18.28:36.31, -4.92:-8.14:-14.82, flag,,,d_CK, d_TD);
$setuphold(posedge CK, negedge TD &&& SEL, 22.09:38.87:79.21, -7.51:-9.99:-14.21, flag,,,d_CK, d_TD);
$setuphold(posedge CK, posedge SEL, 22.58:38.87:78.10, -4.92:-7.64:-13.35, flag,,,d_CK, d_SEL);
$setuphold(posedge CK, negedge SEL, 11.61:19.14:35.81, -1.59:-2.59:-3.36, flag,,,d_CK, d_SEL);
// Minimum Pulse Width
specparam mpw_pos_CK = 15.64;
specparam mpw_neg_CK = 17.40;
$width(posedge CK, 6.87:12.53:25.83, 0, flag);
$width(negedge CK, 17.95:30.51:62.04, 0, flag);
endspecify
`endprotect
endmodule
`endcelldefine
when synthesis ,i have used "set_fix_hold clk"
hi,guys,
set clk_skew 0.4ns
in sdf:
(CELL
(DELAY
(ABSOLUTE
(TIMINGCHECK
in stand-cell
output Q;
supply1 vcc;
//Function Block
`protect
buf g3(Q, qt);
//Specify Block
specify
endspecify
`endprotect
endmodule
`endcelldefine
