How to solve the convergence problem while doing Loadpull
promise2007
Newbie level 1
Beijing,China
Hi friends, I encountered a problem while doing PA Loadpull simulation, hpeesoft demonstrated the error information as follows:
A virtual resistance of 1 TOhms was added to each node.
Error detected by hpeesofsim during HB analysis `HB1'.No convergence.
Thank you for your answering.
here is the detaied error informatin:
Warning detected by hpeesofsim during netlist flattening.
    Resistor `X1.AHBT16.R2' is shorted.
    Resistor `X1.AHBT15.R2' is shorted.
    Resistor `X1.AHBT14.R2' is shorted.
    Resistor `X1.AHBT13.R2' is shorted.
    Resistor `X1.AHBT12.R2' is shorted.
    Resistor `X1.AHBT11.R2' is shorted.
    Resistor `X1.AHBT10.R2' is shorted.
    Resistor `X1.AHBT9.R2' is shorted.
    Resistor `X1.AHBT8.R2' is shorted.
    Resistor `X1.AHBT5.R2' is shorted.
Warning detected by hpeesofsim during HB analysis `HB1'.
    No convergence.
    Divergence in the KCL check detected.
    Convergence hints:
    o Double the fundamental oversample.
    o Select the direct solver.
    o Set Matrix Re-use to Robust.
    o Select the Krylov solver.
    o Increase Krylov Restart Length to 150.
    This is the maximum value based on available memory.
    o Try TAHB (transient assisted HB).
    o Select the Robust convergence mode,
    o Increase max. iterations to 100.
    o Select the Fast convergence mode.
    o Increase the order.
    o Try to sweep a parameter.
    o Increase MaxStepRatio.
Status / Summary
Fwd sourceLevel=37.7605e-03    3.78% 2/2  Step=0.2864222517*...    Arclength Newton-Raphson converged at 0.0408357 in 1 iters
Fwd sourceLevel=77.5025e-03    7.75% 2/2  Step=0.4050622329*...    Arclength Newton-Raphson converged at 0.0730659 in 1 iters
Fwd sourceLevel=109.286e-03   10.93% 2/2  Step=0.5728445034*...    Arclength Newton-Raphson converged at 0.103846 in 1 iters
Fwd sourceLevel=140.814e-03   14.08% 2/2  Step=0.8101244659*...    Arclength Newton-Raphson converged at 0.135964 in 1 iters
Fwd sourceLevel=175.799e-03   17.58% 2/2  Step=1.145689007*...    Arclength Newton-Raphson converged at 0.171093 in 1 iters
Fwd sourceLevel=215.196e-03   21.52% 2/2  Step=1.620248932*...    Arclength Newton-Raphson converged at 0.209668 in 1 iters
Fwd sourceLevel=257e-03       25.70% 2/2  Step=2.291378014*...    Arclength Newton-Raphson converged at 0.249224 in 1 iters
Fwd sourceLevel=296.329e-03   29.63% 2/2  Step=3.240497864*...    Arclength Newton-Raphson converged at 0.289854 in 1 iters
Fwd sourceLevel=341.126e-03   34.11% 2/2  Step=4.582756027*..    Arclength Newton-Raphson converged at 0.336746 in 1 iters
Fwd sourceLevel=398.868e-03   39.89% 2/2  Step=6.480995727*....    Arclength Newton-Raphson converged at 0.396277 in 1 iters
Fwd sourceLevel=479.705e-03   47.97% 2/2  Step=9.165512055*.**..*    rejected
Fwd sourceLevel=436.005e-03   43.60% 2/2  Step=4.36452955*...............    Arclength Newton-Raphson converged at 0.441086 in 1 iters
Fwd sourceLevel=515.11e-03    51.51% 2/2  Step=4.36452955*.******    rejected
Fwd sourceLevel=476.336e-03   47.63% 2/2  Step=2.078347405*.*    rejected
Fwd sourceLevel=457.872e-03   45.79% 2/2  Step=0.9896892404*.***    rejected
Fwd sourceLevel=449.079e-03   44.91% 2/2  Step=0.4712805906*    rejected
Fwd sourceLevel=444.893e-03   44.49% 2/2  Step=0.2244193289*..............    Arclength Newton-Raphson converged at 0.446564 in 1 iters
Fwd sourceLevel=453.867e-03   45.39% 2/2  Step=0.2244193289
*.*    rejected
Fwd sourceLevel=450.042e-03   45.00% 2/2  Step=0.1068663471*...    Arclength Newton-Raphson converged at 0.450097 in 1 iters
Fwd sourceLevel=451.27e-03    45.13% 2/2  Step=0.1068663471*..    Arclength Newton-Raphson converged at 0.451044 in 1 iters
Fwd sourceLevel=452.134e-03   45.21% 2/2  Step=0.1511318374*..    Arclength Newton-Raphson converged at 0.451918 in 1 iters
Fwd sourceLevel=452.914e-03   45.29% 2/2  Step=0.2137326942*..    Arclength Newton-Raphson converged at 0.452695 in 1 iters
Fwd sourceLevel=453.548e-03   45.35% 2/2  Step=0.3022636748*..    Arclength Newton-Raphson converged at 0.453316 in 1 iters
Fwd sourceLevel=453.93e-03    45.39% 2/2  Step=0.4274653883*..    Arclength Newton-Raphson converged at 0.453676 in 1 iters
Fwd sourceLevel=453.892e-03   45.39% 2/2  Step=0.6045273496*..    Arclength Newton-Raphson converged at 0.453607 in 1 iters
Rev sourceLevel=453.177e-03   45.32% 2/2  Step=0.8549307767*..    Arclength Newton-Raphson converged at 0.45285 in 1 iters
Rev sourceLevel=451.392e-03   45.14% 2/2  Step=1.209054699*..    Arclength Newton-Raphson converged at 0.451009 in 1 iters
Rev sourceLevel=447.944e-03   44.79% 2/2  Step=1.709861553*..    Arclength Newton-Raphson converged at 0.447484 in 1 iters
Rev sourceLevel=441.928e-03   44.19% 2/2  Step=2.418109399*..    Arclength Newton-Raphson converged at 0.441341 in 1 iters
Rev sourceLevel=431.898e-03   43.19% 2/2  Step=3.419723107*..    Arclength Newton-Raphson converged at 0.43106 in 1 iters
Rev sourceLevel=415.388e-03   41.54% 2/2  Step=4.836218797*..    Arclength Newton-Raphson converged at 0.414006 in 1 iters
Rev sourceLevel=387.921e-03   38.79% 2/2  Step=6.839446213*..    Arclength Newton-Raphson converged at 0.385191 in 1 iters
Rev sourceLevel=340.331e-03   34.03% 2/2  Step=9.672437594*...    Arclength Newton-Raphson converged at 0.333625 in 1 iters
Rev sourceLevel=249.803e-03   24.98% 2/2  Step=13.67889243*.....    Arclength Newton-Raphson converged at 0.226509 in 1 iters
Rev sourceLevel=24.5025e-03    2.45% 2/2  Step=19.34487519    rejected
Rev sourceLevel=130.315e-03   13.03% 2/2  Step=9.211845328*..*    rejected
Rev sourceLevel=180.703e-03   18.07% 2/2  Step=4.386593013*....    Arclength Newton-Raphson converged at 0.17006 in 1 iters
Rev sourceLevel=98.2967e-03    9.83% 2/2  Step=4.386593013
*....*......    Arclength Newton-Raphson converged at 0.0213915 in 2 iters
Solver convergence summary:
RHS:
6.714e-10  A at node X1.AHBT8.HBT1.ei, harmonic index (5)
6.626e-10  A at node X1.AHBT14.HBT1.ei, harmonic index (5)
6.626e-10  A at node X1.AHBT15.HBT1.ei, harmonic index (5)
Update:
9.619e-07  V at node X1.AHBT2.HBT1.ci, harmonic index (1)
9.619e-07  V at node X1.AHBT1.HBT1.ci, harmonic index (1)
9.619e-07  V at node X1.AHBT6.HBT1.ci, harmonic index (1)
Solution:
369        V at node X1.AHBT6.HBT1.ti2, harmonic index (0)
369        V at node X1.AHBT2.HBT1.ti2, harmonic index (0)
369        V at node X1.AHBT4.HBT1.ti2, harmonic index (0)
Simulation finished with errors.
Resource usage:
  Total stopwatch time     =    88.23 seconds.
Simulation terminated due to error.
also came across this error some time ago, any one has some clue on how to modify the design to make it stable enough so that no error will appear.
Why don't you read the hints of ADS in output log??
Use file->save in simulation window.
Anyway, is there any helpful suggestions? I have similar problem with envelop simulation. Tried all ADS's advices...
