How to size nmos and Pmos to achieve greater threshold voltage?
mujju433
Full Member level 3
Full Member level 3
How do u size nmos and Pmos to achieve greater threshold voltage??
Re: Sizing ????????????
You don't.
Have a look at the threshold voltage equations, and you don't find W or L in them!
I can tell you how to size text to make it more readable though!:D
Sizing ????????????
Actually, threshold voltage may be affected by narrow-width and narrow-length effects.
For short channels, the threshold voltage is reduced due to reduced gate control because of the proximity of the S/D regions to the channel.
For narrow channels, threshold voltage increases due to the fact that the fringing fields from the gate raises the surface potential at the edges of the channel.
Hope it helps.
In level 2 equ. for Vt there is no term for L and W but if you look into the higher models of MOS like level 49 or BSIM3 equ there you can see the terms of Weff and Leff, which effects Vt inversly.
