How to simulate printed antenna?
jjantenna
Member level 2
How to simulate single side printed antenna on PCB using NEC? I only care about the radiation pattern, so NEC (MOM based) could be the fastest way. I was told that the printed strip conductors are transformed to circular conductors coated with dielectric or magnetic covers based on the principle of quasi-static energy equivalence, with radiation properties then solved by the usual method of moments for wire antennas. But how?
The following book has this information but I haven't got one:
B. D. Popovic, CAD of Wire Antennas and Related Structures. New York: Wiley, 1991, ch. 2.
Can anyone help me out?
g86
Full Member level 4
On top of antenna :))
Its a good idea. In 4nec2 i have seen planar GND plane. that means another plate has to be defined on it and to be exited properly to get the result for suspended antenna. SuperNEC supports substrates... :idea: ..those who are using superNEC may be able to give a better answer.
I am not sure but dosen't wipl-d use a NEC like code ? It gives o/p very quickly and inputs are very similar to NEC. It can simulate patch antenna.
:!: :idea: :?:
jjantenna
Member level 2
Thank you g86. Frankly speaking, this is my first time hearing about the mysterious wipl-d. I am still interested to know the equalivent length/radius of the wire relating to the thickness/dielectric constant/width of the substrate. Anyone who has that book could tell us the something.
Element7k
Advanced Member level 1
TherealLapland
I might be a little late for this but may I refer you to the following paper:
I am still not very familiar with this technique so if you have had any clues, I will be interested.
Cheers,
Element7k
woshifanka
Full Member level 1
Dear Element7k
it'a pity that the link you provide doesn't work to me )"
kaka
