agrey
verilog always @ (posedge clk or posedge )
Dear all,
I'm writing a 8-bit register with different reset bit. I try to rewite it by using for loop expression but the dc synthesis result is not the same as these two code.
Could someone kindly help me on it ? Thanks a lot.
Below is my rtl code:
module test(sw_rst, wr_en, out, data ,rst, clk);
input wr_en; // write enable
input rst; // global reset
input clk;
input [7:0] sw_rst; // software reset
input [7:0] data;
output [7:0] out;
reg [7:0] out;
always @(posedge clk or posedge rst)
if (rst) out[0] <= #1 1'b0;
else if (sw_rst[0]) out[0] <= #1 1'b0;
else if (wr_en) out[0] <= #1 data[0];
if (rst) out[1] <= #1 1'b0;
else if (sw_rst[1]) out[1] <= #1 1'b0;
else if (wr_en) out[1] <= #1 data[1];
if (rst) out[2] <= #1 1'b0;
else if (sw_rst[2]) out[2] <= #1 1'b0;
else if (wr_en) out[2] <= #1 data[2];
if (rst) out[3] <= #1 1'b0;
else if (sw_rst[3]) out[3] <= #1 1'b0;
else if (wr_en) out[3] <= #1 data[3];
if (rst) out[4] <= #1 1'b0;
else if (sw_rst[4]) out[4] <= #1 1'b0;
else if (wr_en) out[4] <= #1 data[4];
if (rst) out[5] <= #1 1'b0;
else if (sw_rst[5]) out[5] <= #1 1'b0;
else if (wr_en) out[5] <= #1 data[5];
if (rst) out[6] <= #1 1'b0;
else if (sw_rst[6]) out[6] <= #1 1'b0;
else if (wr_en) out[6] <= #1 data[6];
if (rst) out[7] <= #1 1'b0;
else if (sw_rst[7]) out[7] <= #1 1'b0;
else if (wr_en) out[7] <= #1 data[7];
endmodule
Dear all,
input clk;
input [7:0] data;
output [7:0] out;
reg [7:0] out;
endmodule
