How to select ferrite Bead in your Design ?
BuBEE
Full Member level 2
Thailand
ferrite bead selection
Hi all,
I would like to know about your TIP or Technic in ferrite bead selection
Thank you
how to select ferrite bead
Trial and error. Ferrite beads start to word at the frequencies above 1MHz. Find a family of beads that have the same package (like MMZ series tha comed in 0603 and 0805), add the pads to your board and see what works for you.
Reactions: babak86
    BuBEE
    babak86
ferrite bead selection guide
I guess the best way to decide that will be using Signal Integrity tool or digital simulation tools.
You can change the value of ferrite bead by giving desired input.
    BuBEE
how to select a ferrite bead
Beads are selected dependent on purpose in design, working or suppress frequency , needed inductance and max through current . Yet , geometric sizes does matter as well (sometimes).
    BuBEE
how to find the unknown value of a ferrite bead
i went trough this b4, so thrust me on this..get a spectrum analyzer and find the frequency range of ur noise profile..then only select the ferrites..and like artem said, selection are based on design, supression and max thru current..in some hi speed applications material selection is is crucial..
    BuBEE
Re: ferrite bead selection
Look-up the impedance curve on datasheet and then use the bead with highest impedance value for the frequency band you want to suppress the noise.
Also check the DC resistance. only critical for high current line.
To chose the proper bead, you should consider the following:
1. What is the range of unwanted frequencies?
2. What is the source of the EMI?
3. How much attenuation is required?
4. What are the environmental and electrical conditions for the circuit (temperature DC voltage, DC bias currents, maximum operating currents, field strengths, etc...)?
5. What is the maximum allowable profile and board real estate for using this component?
