How to save and load Virtuoso Bindkeys settings?
ald356
Junior Member level 3
Help...
Layout Editor: Virtuoso
Im assigning my own keyboard shortcut in the "Key or Mouse binding" window.
(CIW >>>> Option--> Bindkey)
But how can I save this and load it if I want to use the same key in every session in the future?
Thanks in advance
virtuoso shortcuts
hi
You can write a BindKey program in text editor or vi editor and load it in CIW whenever you start the session. I'm just attaching a small example of the Bindkey program:
hiSetBindKeys( "Layout" list(
; Key [;alternate encodings used for same key]
list("<Key>0" "leHiMoveOrigin")
list("<Key>1" "geSaveWinView()")
list("<Key>2" "geRestoreWinView()")
list("<Key>5" "leHiFlatten()")
list("Ctrl<Key>r" "hiRedraw()")
list("Ctrl<Key>s" "leHiSplit()")
list("Ctrl<Key>w" "leCloseWindow()")
list("Shift<Key>o" "leHiRotate()")
list("Shift<Key>p" "leHiCreatePolygon()")
list("Shift<Key>q" "leEditDesignProperties()")
This way you can create your own bindkeys for the layout editor.
Paramjyothi
virtuoso bindkeys
If u add ur bindkeys in ur .cdsinit file then no need of loading ur bindkeys again and again.
virtuoso layout bindkey
Paramjyothi said:
hi
Paramjyothi
how can load it in CIW? what is the command line?
Added after 59 seconds:
I cannot find the .cdsinit file.. Where it is located? I think my shortcut was not added..How to save the bind keys?
cadence virtuoso bindkeys
.cdsinit is always in ur /home location only.
    ald356
virtuoso layout bindkeys
Write this program in a Notepad or Unix vi Editor and save it say as Bindkeys.il and then in the CIW command prompt type: load "Bindkeys.il" and say enter. That's enough and try these keys.
.cdsinit file is created when you invoke your cadence layout editor (icfb &). This file consists of the setting of your layout editor. You can edit this file in Unix by saying: vi .cdsinit and then edit it.
To do this you need to have min knowledge of unix. If you know it then please follow the above method to load Bindkeys. I have just given some example list you can add anything and anyway you like.
Paramjyothi
Reactions: egx
    ald356
    egx
bindkey virtuoso
Paramjyothi
I will search for this file.. I think its cds.lib in our manner..
Thank you Paramjyothi and amitabh262002
cadence layout bindkey
That is not cds.lib, In cds.lib only we can define our libraries in which we do layouts.
for loading somthing at the time of invoking icfb we must write that commands in .cdsinit not in cds.lib
virtuso bindkey
At Unix prompt if you type: ls -al
Then you can view this file and this file is stored in the same location as the cds.lib. So if you can try the above command, then you can view the file.
Try it out.
Paramjyothi
virtuoso bind key
Paramjyothi
It works.. thank you very much..
Regarding cdsinit.. i really cannot find in the directory of same with cds.lib. And We are not invoking using icfb command.. we use layoutPlus instead..
how to configure a bindkey in virtuoso
This is not necessarily so. There could be some customization put in by IT or CAD personnel that can redirect where to source the .cdsinit. It can be in $HOME or the current working directory or anywhere actually. This is a useful and sometimes necessary feature when working in groups that need structure and organization for large projects.
bindkey shift
u can add ur own bind key file into ur .cdsinit file sothat it will automatically load ur own bindkeys whe u start ur icfb
lebindkey file
.cdsinit is a hidden file.
enable "show hidden file" in your browser setting.
hock
defining bind keys in .cdsinit
hi here is an easy way. you open your layout and use the options>bindkeys from ciw
choose the layout editor as tool and click on "Display bind keys"
this will open a file with all your existing bind keys. including all your modifications.
save it as bind.il ( or what ever you want to call it )
now on you can load this file with load command from CIW to get all your stuff back.
( you need to open atlease one layout so that the functions are available in the memory, before loading this file )
OR
just find out an existing file and make all the changs you need. then it can be loaded from cdsinit
cheers
setting bindkeys in virtuoso
for bindkeys there is one script file , if u want create u r keys edit that file and save it reflects every time no need to upload every time when u r invoking in to the virtuso. that is script file.
i hope it will help u
virtuoso short key
Guys, .cdsinit file will not create automatically when you invoke icfb/virtuoso.. You need to create this file if u r want to use some custom settings/scripts...
