how to replicate a pcb design in altium
swap7etc
i need to replicate the pcb layout with or without routing for 12 times,kindly help for this.
did u try ctrl+c for copy and ctrl+v for paste(select whole layout before copy) ?? it will work.
i tried this but i want it along with nets, as the part is in schematic and i need to form a replica using the components with nets as like a template.
If you need net information after copying the design, go to Design/Netlist/Configure physical nets.
This will assign net name's as NewNet1, NewNet2......
Rgrds,
Anil
you can use the room function!
I have a problem with copying rooms. Routing hasn't been copied although it is thicked in 'copy room formats' options.
