how to read ascii data in a file using c
jyothib86
Newbie level 6
mysore
hello every one am new to c can anybody tell me how to read ascii eeg data ..
thanks in adance..
Can you post or upload the ascii file you're attempting to read?
You might also include your program as well.
Can you elaborate the doubt in detailed....
i have collected eeg data where i have read its 2(time) and 4 (amplitude)column to get the waveform which r in ascii version am attaching the one such data plz suggest me
  • fifty.TXT
i have done it in matlab but i want to try in c also so plz suggest me . i have a eeg data which is in ascii form i need to read 2 (time)and 4 (amplitude)column to plot the signal am attaching the related data .
  • fifty.TXT
in c Asci value reading ,you can take the following method
#include<stdio.h>
void main()
int i;
char c;
printf("Enter a Character To convert the ASCI value \n");
Scanf("%c",&C)
i=c;
printf(" the converted ASCII value is is %d",i);
You dont need any particular logic to read ASCII data....just simply
print the data like
printf("%d ",variable);
so that it prints the data that corresponding to ASCII value..........
Trim your data file down to the essential columns:
1,-12.78, -31116, -0.09, -14441, -0.04, -16675, -0.05
2,-12.75, -24519, -0.07, -10620, -0.03, -13899, -0.04
3,-12.73, -18812, -0.06, -7205, -0.02, -11607, -0.03
4,-12.70, -14236, -0.04, -4411, -0.01, -9825, -0.03
5,-12.68, -10850, -0.03, -2366, -0.01, -8484, -0.03
6,-12.65, -8537, -0.03, -1102, -0.00, -7435, -0.02
7,-12.63, -7035, -0.02, -552, -0.00, -6483, -0.02
8,-12.60, -6002, -0.02, -567, -0.00, -5435, -0.02
9,-12.58, -5089, -0.02, -948, -0.00, -4141, -0.01
10,-12.55, -4014, -0.01, -1475, -0.00, -2539, -0.01
11,-12.53, -2616, -0.01, -1948, -0.01, -668, -0.00
12,-12.50, -895, -0.00, -2219, -0.01, 1324, 0.00
13,-12.48, 1005, 0.00, -2208, -0.01, 3213, 0.01
14,-12.45, 2825, 0.01, -1909, -0.01, 4734, 0.01
15,-12.43, 4262, 0.01, -1381, -0.00, 5643, 0.02
16,-12.40, 5038, 0.02, -727, -0.00, 5765, 0.02
17,-12.38, 4981, 0.01, -66, -0.00, 5047, 0.02
18,-12.35, 4074, 0.01, 498, 0.00, 3576, 0.01
19,-12.33, 2482, 0.01, 900, 0.00, 1582, 0.00
20,-12.30, 535, 0.00, 1128, 0.00, -593, -0.00
21,-12.28, -1318, -0.00, 1227, 0.00, -2545, -0.01
22,-12.25, -2594, -0.01, 1285, 0.00, -3879, -0.01
23,-12.23, -2857, -0.01, 1415, 0.00, -4272, -0.01
24,-12.20, -1809, -0.01, 1726, 0.01, -3535, -0.01
25,-12.18, 649, 0.00, 2296, 0.01, -1647, -0.00
26,-12.15, 4390, 0.01, 3154, 0.01, 1236, 0.00
27,-12.13, 9072, 0.03, 4266, 0.01, 4806, 0.01
28,-12.10, 14191, 0.04, 5540, 0.02, 8651, 0.03
Declare a file handle
FILE *my_data;
Use fopen to open file for reading
my_data = fopen (my_filename, "r");
Then use fscanf to read data into predeclared variables
fscanf (my_data, "%f %f %i %i", &f1, &f2, &i1, &i2);
Then close the file using fclose
fclose (my_data);
Example of using these functions:
fscanf()
You can test the fscanf call in a while loop, when it returns null, end loop.
