how to program this code from DS18S20@DS1820 to LM 35..please help me..thank :)
chomix05
Newbie level 5
Use CODE tags when posting your code
list      p=16f628
#include <p16f628.inc>
errorlevel 0,-302
CBLOCK	0x20
DS_DAT
DS_SIGN
DUMMY0
DUMMY1
DUMMY2
DUMMY3
DUMMY4
SEND
COUNT
NUM1
NUM2
NUM3
DATA1
HALF
	endc
#define	DAT_PIN	PORTB,0		; 74595 DATA pin
#define LATCH	PORTB,4		; 74595 LATCH pin
#define CLK	PORTB,5		; 74595 CLK pin
#Define	DQ	PORTA,0
	org	0x000
	goto	Start
Table_	addwf	PCL,f
	dt	0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
Start	clrf	PORTA		; Set port A for digital I/O
	movlw	0x07
	movwf	CMCON
	bsf	STATUS,RP0
	movlw	b'00000110'	; Set port B for displaying via LED 7 segments
	movwf	PORTB
	bcf	STATUS,RP0
Main	call	RD_Temp	; Read data from DS1820
	clrf	HALF		; A Half digit
	bcf	STATUS,C
	rrf	DS_DAT,w	; Use 7-bit upper
	rlf	HALF,f		; Store a half degree
	movwf	DATA1		; Data for convert to decimal
	call	Convert		; Convert data to decimal
	call	Delay3		; Display data delay
	goto	Main
;	Display On 7 Segment 					      *
Delay3	clrf	DUMMY4		; Display data delay
DelayLp	call	Disp
	decfsz	DUMMY4,f
	goto	DelayLp
	return
Delay2	clrf	DUMMY3		; Delay for scanning LED 7 segments
	decfsz	DUMMY3,f
	goto	$-1
	return
Disp	movf	NUM1,w		; Load data to DSP1
	call	Table_		; Convert
	btfsc	HALF,0		; Show a half degree on dot-point LED
	addlw	0x80
	call	Send_Dat		; Send data to LED 7 segments
	bcf	PORTB,6		; ON DSP1 Display
	call	Delay2
	bsf	PORTB,6
	movf	NUM2,w		; Load data to DSP2
	bcf	PORTB,7		; On DSP2
	call	Delay2
	bsf	PORTB,7		; Off DSP2
	return
Send_Dat movwf	SEND		; Load data
	movlw	0x08		; Loop 8 times for sending 8-bit data
	movwf	COUNT
Chk_Bit	bcf	DAT_PIN		;
	btfsc	SEND,7		; Check bit 7 "0" or "1"
	bsf	DAT_PIN		; Send bit 7 to shift register
Clock	bsf	CLK		; Clock pulse
	bcf	CLK
Rotate	rlf	SEND,f		; Rotate bit for sending next bit
	decfsz	COUNT,f		; Test loop 8 times ?
	goto	Chk_Bit		; If no, send bit again
Latch	bsf	LATCH		; Latch data for displaying
	bcf	LATCH
	return
;	Macro for DS1820					      *
DQLOW	macro
	bcf	DQ		; DQ bit ready
	bsf	STATUS,RP0
	bcf	DQ		; Set DQ to output
	bcf	STATUS,RP0
	endm
DQHIZ	macro
	bsf	STATUS,RP0
	bsf	DQ		; Set DQ to input
	bcf	STATUS,RP0
	endm
PAUSE	macro	DELAY		; Generate delay time
	movlw	DELAY
	movwf	DUMMY0
	call	Delay5
	endm
;    	DS1820 1-Wire bus                                             *
RD_Temp	call	DS_Rx		; Check chip status
	addlw	0x01
	btfss	STATUS,Z	; Z set = ready
	return			; W is not zero = not ready
Get_Temp call	DS_Reset
	movlw	0xcc		; Skip ROM
	call	DS_Tx
	movlw	0xbe		; Read scratch pad RAM of DS1820
	call	DS_Tx
	call	DS_Rx		; Read 8-bit data
	movwf	DS_DAT
	call	DS_Reset	; Restart
	call	DS_Tx
	movlw	0x44		; Start conversion
	call	DS_Tx
Delay5	nop			; Delay for PAUSE  macro
	nop
	decfsz	DUMMY0,f
	goto	Delay5
	return
DS_Reset DQLOW
	PAUSE	0x77		; 600 microcsecond delay
	DQHIZ
	PAUSE	0x0c		; Wait  for response pulse (67 microsecond)
	nop
	nop
	movf	PORTA,w		; Read response
	andlw	0x01		; Use RA0 only
	movwf	DUMMY1
	PAUSE	0x3b		; 300 microcsecond delay
	movf	DUMMY1,w	; Response in W
	return
DS_Tx	movwf	DUMMY2		; Transmission data
	movlw	0x08		; Prepare 8-bit counter for sending data
	movwf	DUMMY1		; Define loop counter
Tx_Loop	DQLOW			; Macro of DQ pin to low, This is start bit
	PAUSE	0x01		; 10 microsecond delay
	rrf	DUMMY2,f	; Rotate data to Carry flag
	btfsc	STATUS,C	; Test Carry flag
	bsf	DQ		; If Carry flag = "1" , set DQ to high
	PAUSE	0x0d		; 70 microsecond delay
	DQHIZ
	nop
	decfsz	DUMMY1,f	; 8 times ?
	goto	Tx_Loop		; No, send again
	return
DS_Rx	movlw	0x08		; Recieve 8-bit data
	movwf	DUMMY1
Rx_Loop	DQLOW			; Macro of DQ pin to low, this is start bit
	DQHIZ			; Back to high for receiving
	nop
	nop
	movf	PORTA,w		; Read data
	andlw	0x01		; Get data bit 0 only
	addlw	0xff		; Move data bit 0 to Carry flag with addition method
	rrf	DUMMY2,f	; Move data bit 0 to DUMMY bit 7
	PAUSE	0x0b		; 60 microsecond delay
	decfsz	DUMMY1,f	; Loop 8 times
	goto	Rx_Loop		; Read again
	movf	DUMMY2,w	; Save data to W register
	return
;    	Convert Hex to  Decimal	(3 Digit)			      *
Convert	clrf	NUM2		; Clear register of 10's unit
Check	movlw	0x0A		;
	subwf	DATA1,w		; Subtract with 10 until lower 10
	btfss	STATUS,C	; Check subtraction result lower 10 ?
	goto	Less1		; If yes then return
	incf	NUM2,f		; If no, increase 10's unit value
	movlw	0x0A		;
	subwf	DATA1,f		;  Subtract with 10 until lower 10 and check result again
	goto	Check
Less1	movf	DATA1,w		;
	movwf	NUM1		; Send data to 1's unit display
	clrf	NUM3		; Check hundred unit
Check2	movlw	0x0A
	subwf	NUM2,w		;
	btfss	STATUS,C	; 10's unit over 10 ?
	return			; If no then return
	incf	NUM3,f
	movlw	0x0A		; If yes, subtract again and check until the result is lower 10
	subwf	NUM2,f
	goto	Check2
	end
Your request for advice concerning the code you have posted is unclear.
Do you want to convert the code from using a DS1820 to a LM35 as the temperature sensor?
The two sensors you mentioned, the DS1820 and the LM35 operate on two very distinctly different principles, the display routines are most likely the only code which can be utilized with either sensor.
BigDog
oke sir..i know the sensor is same function as temperature sensor..can you help me to edit the code using LM35???
While they are both temperature sensors, their interface requirements are totally different. The DS18S20 outputs the temperature data in digital format utilizing a 1-Wire interface, while the LM35 is a purely analog device and requires the implementation of the PIC's ADC module.
The following example is in C rather than assembly language, however it should give you some guidelines on how to initialize the ADC module for use with the LM35:
Interfacing LM35 Temperature Sensor with PIC Microcontroller.
The following tutorials cover both 7-segment Displays and ADC module in Midrange PIC Assembly Language:
I would recommend studying the links I have posted above, attempt to modify the code to utilize the ADC module in conjunction with the LM35.
If you have any additional problems, post your updated code with a description of the issue and I will be glad to assist you further.
BigDog
