How to produce this sequence using shift register?
anantha_09
Member level 4
Member level 4
Can you produce this sequence? Draw the schematic, hint: use a
shift register.
0 0 0 0
1 0 0 0
1 1 0 0
1 1 1 0
1 1 1 1
0 1 1 1
0 0 1 1
0 0 0 1
Re: interview question
shift right, invert the bit that falls off the right and feed it into the left end of the shift register.
hav u got any more problems of this kind or let me know wher can i find some of these kind
shift register.
0 0 0 0
1 0 0 0
1 1 0 0
1 1 1 0
1 1 1 1
0 1 1 1
0 0 1 1
0 0 0 1
hum.....not sure which is the best answer but my answer would be.
RTL:
reg shift [3:0];
always @(posedge clk or reset_n) begin
if (!reset_n)
shift <= 4'b0000;
else
shift <= {!shift[0], shift[3], shift[2], shift[1]}
end
correct? if wrong pls let me know
interview question
hi anantha
u are given that sequence is the detected johanson counter.it is working the last ff output inverte to the feed back of the first ff input.u want more details u r study the johanson counter
vamsi
LaTeX Commands Quick-Menu:
