how to print node capacitor in spectre?
wateror
Member level 4
captab spectre
we can use .print cap(node) to plot capacitor curves in hspice. But how do we do that in spectre? I found there was a captab option in transient analysis. But it seems that it only calculate a capacitors at one point...
Is there any idea?
cadence captab
I had done a function request to Smash some years ago to implement the printing of node capacitance and node impedance. These infos are side effects of the modified nodal analysis but still not used in simulators.
I need it some years ago for detection of floating nodes in analog circuit. I know that for digital TL there exist something but for analog there is nothing. You have to reason all transistors and all modes for your self. That is still the case.
I have heard that this functions is now implemented in Smash.
spectre captab
could you try the option captab=1,
see if it works.
mos spectre capacitance
captab=1? do you mean I should write spectre netlist? But I really want to do it in Analog enviorenment...
captab option in spectre
captab option is there in analog environment also. there is a switch under analysis options,that you need to enable.
