themaccabee
Full Member level 4
Hi all,
I ve got a dual directional coupler Narda 3020A which has a minimum directivity of 35dB.But can somebody tell me how to measure the same?
I was following the readings at
Power dividers and directional couplers - Wikipedia, the free encyclopedia
Using directional couplers
The second one details a method for measuring directivity
But when i do so
Input power =0dBm at 500MHz
Coupling at 500MHzat REV Port=20.11dB
Power measured at REV Port for 0dBm input=-41.72dBm
So according to the webpage the directivity is 41.72-20.11= 27.61dB only
The other ports are terminated by 50Ohms as said.
the datasheet guarentees minimum 35dB directivity
Im i wrong in calculation/measurements? Can somebody correct me??
Regards
Steve.
But when i do so
![0608Tech-Speak_fig2.gif](https://urgentcomm.com/techspeak/0608Tech-Speak_fig2.gif)
Regards
Steve.
