how to make an electric arc
23ronnie11
Newbie level 6
hello
can anyone help me to make a powerful electric arc about 1cm long
It should be really powerful and need not be long
Is it better to use DC or AC
klystron
South Africa
Build a Tesla coil, Jacobs ladder, a car ignition coil, the flash circuit of a disposable camera or electronics of a fly zap racket
chuckey
Advanced Member level 5
Southampton and holiday cottage in Wensleydale (UK
DC gives you a more steady arc, although there is erosion of one of your electrodes. FWIW, the arc impedance is about .5 Ohms though a much higher voltage is required to strike the arc. I would Google "Tesla coils". It all depends on what you want to use the arc for.
Frank
23ronnie11
Newbie level 6
i need a continuous arc to heat up air .i just need a simple and effective way to make a small but powerful arc.
is high voltage required to make a powerful arc ..so what should i use a flyback transformer or a mot
klystron
South Africa
Use a LM555 oscillator driving a power transistor with a car ignition coil as a collector load
FvM
Super Moderator
Staff member
Bochum, Germany
To comment some previous posts, I think electrical arc isn't the same as a high voltage spark, as achievable with an ignition coil.
An electric arc is a plasma discharge maintained by the supplied power. The classical carbon arc lamp has been operated at about 30 to 60 V AC with currents of 10 to 100 A. You'll need a high current transformer with high leak inductance, e.g. a welding transformer. Some safety risks related to arc discharge should be considered:
- strong UV radiation, dangerous to eyes and unprotected skin
- generation of nitrouses gases and ozone
23ronnie11
Newbie level 6
I need a continuous arc not a spark .i need this arc to make an arc rocket so any suggestions .the problem with a tesla coil is that it is to big . i think a car ignition coil can only give a spark .Do you guys think i should use a flyback transformer or a mot .if you think the flyback is better can you suggest a good driver circuit
chuckey
Tesla coils are only big because they need to be else the voltage they produce will flash between the turns of the coils. Using lower power and lower voltages would mitigate against the size. An oil filled ignition coil is a very good start because of the oil dielectric they can pack more voltage into a smaller space. You can also get them from car scrappers for loose change. In a car they only produce a spark because that what the driving circuit does.
FWIW Years ago I built an electronic ignition circuit to my own design and got the design wrong. The result was a continuos discharge that flashed across from the HT contact to the case of a ignition coil, a distance of about 50 mm.
Frank
23ronnie11
Newbie level 6
i may need kw power level .
please can you show that circuit (ignition coil) .can i adapt that for a flyback transformer though i don't need a 5cm long arc
FvM
Super Moderator
Staff member
Bochum, Germany
Before discussing about circuits, some points should be clarified:
- What's the intended primary power source for the electric arc?
- How do you intend to ignnite it? As already mentioned, altough the operation voltage of the arc will be low (several 10 V), a high voltage source is required for ignition. Alternatively, it can be ignited by making the electrodes touch, as usual with arc welding or a classical carbon arc lamp.
atferrari
Full Member level 4
Buenos Aires - Argentina
Search for...
I recall the film projectors used when I was a kid (is the system the same today?).
There were two carbon rods with the ends kept at a constant distance from each other. Never had the chance to see how it actually worked.
They generated LOT of heat.
Look also for the technology used for the big reflectors (WWII) to illuminate targets for gunnery. IIRC they used a similar principle. Searchlight or spotlights.
FvM
Super Moderator
Staff member
Bochum, Germany
You are referring to carbon arc lamps. I already mentioned it. See this wikipedia article for the different techniques Arc lamp - Wikipedia, the free encyclopedia
Today's cinema projectors are exclusively using high pressure xenon arc lamps.
Carbon arc lamps usually have an electromagnetical mechanism that controls the electrode distance, keeping the current at a defined setpoint.
23ronnie11
Newbie level 6
i haven't thought about the power source .what do you suggest
an eliminator
or a battery
i don't think i will be able to make a contact after the rocket is made
23ronnie11
Newbie level 6
i am not sure if i will need kw power .but if it is required what power source should i use and what should i use to get the arc
FvM
Super Moderator
Staff member
Bochum, Germany
You didn't clarify your intentions exactly. Some comments make me think, that you want to actually fly an arc rocket. I assume that it can't work because no available electrical power source has the energy density (in terms of E/m) to generate a sufficient thrust. But it's just a guess.
Moving a vehicle by an arc rocket propulsion for demonstration purposes may be possible. For a mobile device, super capacitors offer the highest specific power in a 0.1 to 10 sec time scale, for longer experiment duration, NiMH or Li-Ion battery would be preferable.
23ronnie11
Newbie level 6
i don't want to fly the rocket i just want make a working model that produces a small thrust
FvM
Super Moderator
Staff member
Bochum, Germany
That's good. I already suggested a standard arc welding transformer as power source. It would require an additional high voltage ignition circuit, if you can't ignite the arc by shorting the electrodes. With a battery or supercap, an inverter is needed.
But I guess, you should start with the thermodynamical design. It should clarify the arc power demand.
23ronnie11
Newbie level 6
the problem is that i don't have an arc welding transformer i don't think i will be able to get one .but i can get a mot of a flyback transformer .Do you think heating the gas before going to the electrodes make it easier to make the arc
