How to make a XOR gate with some diodes and resistors?
Navid T
Full Member level 3
Full Member level 3
Iran
Hello
how can i make an Xor gate with some diods and resisors?
Thank you
Xor
what do this question in uC part ??
to the answer
try to make transitors with the diodes and search how to make Xor from Trans
Xor
Actually yes, but some tricks with output signal ground will be required - use diod bridge with inputs connected to it and resistor to its output . If inputs are not equal - you will get True on resistor otherwise False.
