how to make 4 bit x 4 bit multiplier with couple of 4 bit adders and gates?
moonnightingale
Full Member level 6
problemof adder
I know how to make it with and gates and 1 bit full adder but how to use 4 bit adders
https://www.edaboard.com/threads/188698/
NOthing is different from the pic you posted.
I'll give you a hint as below, and you'll take care of the rest.
            a3  a2  a1  a0
        b3  b2  b1  b0
    c3  c2  c1  c0
d3  d2  d1  d0
FA  (.A({'0', a3, a2, a1}),  .B({b3, b2, b1, b0}, .S(sum0[3:0]), .CO(co0));
FA  (.A({co0, sum0[3:1]}),   .B({c3, c2, c1, c0},  .S(sum1[3:0]), .CO(co1));
FA  (.A({co1, sum1[3:1]}),   .B({d3, d2, d1, d0}, .S(sum2[3:0]), .CO(co2));
    V
Can u draw a picture for 4 bit x 4 bit unsigned multiplier using 4 bit adders, and upload here
i will be highly grateful to you for that
All you need now is 16 AND gates that generate part products, and plug them to the addition part that I showed you in my last post.
If you still don't understand what I mean, I'd suggest to carefully analyze how the long multiplication is performed in binary.
Sir i am new in this field. I am working hard. As far as Full adder is concerned, it is clear to me but i am stuck with 4 bit adder
Can u kindly send the picture or send me some site from where i can get it
Assuming you understand Verilog netlist.
Signal names based on the long multiplication you posted.
AND (.A(A0), .B(B0), .Y(A0B0));
AND (.A(A1), .B(B0), .Y(A1B0));
AND (.A(A2), .B(B0), .Y(A2B0));
AND (.A(A3), .B(B0), .Y(A3B0));
AND (.A(A0), .B(B1), .Y(A0B1));
AND (.A(A1), .B(B1), .Y(A1B1));
AND (.A(A2), .B(B1), .Y(A2B1));
AND (.A(A3), .B(B1), .Y(A3B1));
AND (.A(A0), .B(B2), .Y(A0B2));
AND (.A(A1), .B(B2), .Y(A1B2));
AND (.A(A2), .B(B2), .Y(A2B2));
AND (.A(A3), .B(B2), .Y(A3B2));
AND (.A(A0), .B(B3), .Y(A0B3));
AND (.A(A1), .B(B3), .Y(A1B3));
AND (.A(A2), .B(B3), .Y(A2B3));
AND (.A(A3), .B(B3), .Y(A3B3));
4BIT_ADDER  (.A({1'b0, A3B0, A2B0, A1B0}),  .B({A3B1, A2B1, A1B1, A0B1}), .CI(1'b0), .S(sum0[3:0]), .CO(co0));
4BIT_ADDER  (.A({co0, sum0[3:1]}),          .B({A3B2, A2B2, A1B2, A0B2}), .CI(1'b0), .S(sum1[3:0]), .CO(co1));
4BIT_ADDER  (.A({co1, sum1[3:1]}),          .B({A3B3, A2B3, A1B3, A0B3}), .CI(1'b0), .S(sum2[3:0]), .CO(co2));
BUF  (.A(A0B0),    .Y(P0));
BUF  (.A(sum0[0]), .Y(P1));
BUF  (.A(sum1[0]), .Y(P2));
BUF  (.A(sum2[0]), .Y(P3));
BUF  (.A(sum2[1]), .Y(P4));
BUF  (.A(sum2[2]), .Y(P5));
BUF  (.A(sum2[3]), .Y(P6));
BUF  (.A(co2),        .Y(P7));
Draw a logic circuit of above by yourself and compare it to the long multiplication to figure out how the above circuit runs multiplications.
Ok kindly tell me what is the function of those large big arrows at the end.Rest i have understood they are there for Carry
Fromthe diagram i am understanding that last two Full adders at the bottom will have two carry inputs?? is it correct
Lastly kindly help me to write boolean expression for this diagram. just tell me the method by writing 2 or 3 expressions
One carry goes to a data input, another goes to carry in.
You can't write a boolean expression with Full adder as a block because addition isn't a part of boolean expression. You have to break the full adder into more primitive functions.
Boolean functions for bit0 and bit1 would be like this.
P0 = A0 AND B0
P1 = (A0 AND B1) XOR (A1 AND B0)
The Boolean Expression for P2 will be
(A2 AND B0) XOR (A1 AND B1) OR (A0 AND B2)
AM i right in saying this
Not correct.
No offense, but you need to understand how addition works before going into multiplication. Read a digital design book.
