[ARM] How to lock desired frequency in PLL LPC2148
karthickv
Newbie level 1
hi guys,
Iam using timer in lpc2148 and i have doubt in the below code
PLL0CON = 0x01; //Enable PLL
PLL0CFG = 0x24; //Multiplier and divider setup
PLL0FEED = 0xAA; //Feed sequence
PLL0FEED = 0x55;
while(!(PLL0STAT & 0x00000400)); //is locked?
if PLL0STAT is the status of PLL0.Then what is 0x00000400 i saw in google that is desired frequency. if it is desired frequency then how i determine the desired frequency in hexa decimal.Thanks in advance
No, it's a mask for checking locked state in status register.
Desired PLL frequency is determined by crystal frequency, multiplier and divider values.
Better review LPC214x User manual, chapter 4.8 PLL.
