assuming that you are looking for spatial points of 50ohm then:
if you have access to the E and H fields of you simulation data then the 50ohm point(s) will be the point(s) at which the ratio of the E and H fields corresponding to 50ohm (of course scaled by some factors. also the E and H field must be in phase if you are looking for real 50ohm).
