How to initialize RAM in Verilog?
littlestewie
I am trying to initialize a RAM using the following code,but Quartus says
Error (276000): Cannot synthesize initialized RAM logic "ram:my_ram|mem"
initial
begin
$readmemh("init.dat",mem);
end
How can i initialize this RAM?Do i have to enter the 256 value by hand?
$readmem is said to be supported by Quartus. I guess there's something special with your design.
this is my module ,what may be wrong?
module ram(
address , // Address input
q    , // Data output
qin	,// Data input
we		//write enable
input [15:0] address;
output wire [7:0] q;
input [7:0] qin;
input we;
reg [7:0] mem [0:255] ;
//reg [7:0] q;
reg [7:0] data_out;
  //$readmemb("memory.list", mem); // memory_list is memory file
  assign q = (!we) ? data_out:8'bz;
  always @ (  address or we)
begin
if (we)
begin
mem[address] = qin;
end
else
begin
data_out = mem[address];
end
end
initial
begin
end
endmodule
The error message is misleading. Your design doesn't infer block RAM with or without $readmem() because it's not a synchronous RAM description. You need something like this:
module ram(
clk,
q    , // Data output
qin	,// Data input
we		//write enable
input [7:0] qin;
input we;
input clk;
reg [7:0] data_out;
always @ (posedge clk)
begin
  if (we)
  begin
    mem[address] = qin;
  end
end
initial
begin
end
endmodule
module ram(
clk,
q    , // Data output
qin	,// Data input
we		//write enable
input [7:0] qin;
input we;
input clk;
reg [7:0] data_out;
begin
  if (we)
  begin
    mem[address] = qin;
  end
end
initial
begin
end
endmodule
thanks a lot.
your solution worked ,but i didn't understand why my code didn't work.
Altera block RAM is synchronous and doesn't work without a clock.
