how to increase the frequency of current steering DAC?
imfresh
Newbie level 6
Newbie level 6
Hi, all
The DAC's load res and cap are fixed, so how to increase the frequency of this DAC?
thanks
If your load and FS current are fixed and If You need to design DAC operating with higher sampling frequency without dynamic behaviour deterioration (the same SFDR, SNHR, etc) You need to increase output impedance of DAC for this frequency (SFDR ~ Zout/Rload) and proper design of digital part.
Look for the Van den Bosch, Borremnas and Steyart papers about high speed nyquist DACs.
It's more likely that settling time is what's limiting
you, and with fixed load attributes the only thing
that will let you run faster sample rate is lower
accuracy expectations. Presuming you are accuracy
limited now. And what -is- limiting you now?
Thank you for your reply.
settling time is limiting me. and LSB current is fixed too.
