Anwesa Roy
We have computed the code considering integers. We need to replace the integers by float. Please help.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.std_logic_signed.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity lms2 is Port (wr9,wi9,xr,xi,u : in STD_LOGIC_VECTOR (12 downto 0); --u : in integer; yr,yi,er,ei,wr8,wi8,zzz,sum1 : out STD_LOGIC_VECTOR (12 downto 0)); end lms2; architecture Behavioral of lms2 is --variable r,s : real range 0.0 to 15.0; begin process(wr9,wi9,u,xr,xi)--process also runs without the parameters,but it gives problems during simulation --process(u,xr,xi) variable wr : std_logic_vector(12 downto 0); variable wi : std_logic_vector(12 downto 0); --variable wr : std_logic_vector(4 downto 0) :="00010"; --variable wi : std_logic_vector(4 downto 0) :="00011"; --variable wr : std_logic_vector(4 downto 0) :=wr9; --variable wi : std_logic_vector(4 downto 0) :=wi9; variable yr1 : integer; variable yi1 : integer; variable er1 : integer; variable ei1 : integer; variable wr1 : integer; variable wi1 : integer; variable uu : integer; variable zz : integer; variable sum : integer:= 0; begin --process(xr,xi,u) --bi <= to_integer(unsigned(k)) ; --bj <= to_integer(unsigned(l)) ; --bk <= bi*bj; uu := to_integer(unsigned(u)) ; wr := wr9; wi := wi9; for z in 0 to 1 loop yr1 := to_integer(unsigned(wr))*to_integer(unsigned(xr))- to_integer(unsigned(wi))*to_integer(unsigned(xi)); yi1 := to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(wi))*to_integer(unsigned(xr)); er1 := to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xr)); ei1 := to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(wi))*to_integer(unsigned(xr))-to_integer(unsigned(xi)); wr1 :=uu*(to_integer(unsigned(xr))*to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(xr))*to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xr))*to_integer(unsigned(xr))-to_integer(unsigned(xi))*to_integer(unsigned(wr))*to_integer(unsigned(xi))-to_integer(unsigned(xi))*to_integer(unsigned(wi))*to_integer(unsigned(xr))+to_integer(unsigned(xi))*to_integer(unsigned(xi))+to_integer(unsigned(wr))); wi1 :=uu*(to_integer(unsigned(xr))*to_integer(unsigned(wr))*to_integer(unsigned(xi))+to_integer(unsigned(xr))*to_integer(unsigned(wi))*to_integer(unsigned(xr))-to_integer(unsigned(xr))*to_integer(unsigned(xi))+to_integer(unsigned(xi))*to_integer(unsigned(wr))*to_integer(unsigned(xr))-to_integer(unsigned(xi))*to_integer(unsigned(wi))*to_integer(unsigned(xi))-to_integer(unsigned(xi))*to_integer(unsigned(xr))+to_integer(unsigned(wi))); --o <= std_logic_vector(to_unsigned(i,5)); wr := std_logic_vector(to_unsigned(wr1,13)); wi := std_logic_vector(to_unsigned(wi1,13)); zz :=z; sum := sum+2; yr <= std_logic_vector(to_unsigned(yr1,13)); yi <= std_logic_vector(to_unsigned(yi1,13)); er <= std_logic_vector(to_unsigned(er1,13)); ei <= std_logic_vector(to_unsigned(ei1,13)); wr8 <= wr; wi8 <= wi; zzz <= std_logic_vector(to_unsigned(zz,13)); sum1 <= std_logic_vector(to_unsigned(sum,13)); end loop; end process; end Behavioral;
