How to generate high frequecny clock signal
Full Member level 4
when I designed some circuit, sometimes I need high frequecy clock signal.
yes. function generator did. but high frequency and High resoultion function
generator is not cheap. It is not possible to buy very expensive function generator.
How do you deal with this problem? Do you have any good solution or experience?
thanks
What kind of circuit do u need the high frequency clock for??
    020170
If frequency you are after is below 20MHz you may consider the MAX038 generator .. see picture below ..
More info at:
Regards,
IanP
    020170
Is there anyone who have any other solution?
I need much more high frequecny clock signal generator, like 300Mhz
Hi
As MSSN asked, What kind of circuit do you need the high frequency clock for?
You can't say only “300Mhz”.
At less, you need to know the following characteristics:
Jitter
Output Level
Duty Cycle
Tolerance (%)
Output Power
Max Consumption
Usually for this frequencies, you can use a based crystal oscillator (reference), VCO (oscillator), Comparator and a divider (prescaler). That is PLL.
Don’t forget the temperature range, it is very important. (Temperature compensated)
Regards
Pont de Pedra
    020170
Pont de Pedra, you are right
my question is thoughtless
IanP:
The MAX038 was a good chip, but it is being discontinued
