vishal_sonam
Full Member level 3
hello
i m new to hfss and i dont know how to feed the antenna with CPw feeding.
as i know, in CPW feeding the ground plane is use to be above the sustrate but i m confused because then patch is also above the substrate so if we put the ground plane above the substrate then how i will assign the ground plane as ground and how will i differentiate between the ground and the patch because they both are already above the substrate.
regards
vishal.
regards
vishal.
