How to enhance the operation frequency of an amplifier?
abcyin
Full Member level 4
Full Member level 4
Hi, all,
For a simple differential amplifier, with resistor load or diode-connected MOSFET load, how to enhance the operation frequency to, for example, 3GHz. I am using a 0.35um BiCMOS process, and I found that it's a little bit difficult to make this possible, so could anybody tell me is there any way to make it?
Any circuit structure or hints are welcome, Thanks in advance.
use BJT as input pair and pump enough current to get a good gm, if the capacitive output load is high... well is it? what's the application?
3GHz might be impossible for the process in point view of nowaday's theory.
Hi leo,
I doubt intrinsic device bandwidth would be a problem in 0.35 SiGe process, a quick sample of one of their models shows tau_f (forward transit time) setting a limit (for infinite gm) transition frequency ~180GHz, which should leave enough margins when you take into account gm and intrinsic caps
I supposed Si process. Thanks.
