How to drive DC servo motor using step/dir signals ?
semsem
Newbie level 1
servo motor controller
how can i drive dc servo motor by using step/dir signals
Re: servo motor controller
Step/dir signals are usually related with stepper motors and not with DC servo motors. Usually DC servo motors are velocity controlled not position (step) controlled) in open loop. If you want to control positon with a DC servo motor you need a positon sensor feedback. Please try:
Modern Control Engineering, Katsuhiko Ogata...
"how can i drive dc servo motor by using step/dir signals" <---- This is not enough information.
You want to drive what? The Velocity or the Position? All is Ok! Just use PID. It is simple and easy to use. Don't ask me what is PID because you can find it on this forum.
Your control must close loop, not open loop.
you said (by using step/dir signals ), I think U need to MATLAP simulation.
hi
if you have modoling control system by c.dorf
