How to draw BGA in schema
pcbman
Member level 5
Member level 5
Hi all,
How BGA symbols you use in your schemas?
Could you send to me a screen capture?
Thank's
pcbman
hi,
BGA symbol can be created as a hetrogeneous part. ie you can split it into different banks.For eg:if there are 4 banks in BGa it can be split into 4 parts.
Apart from the in built library we can create our own library for the parts.
In the schematic desin select file>new>library.
A file with extn .olb will be formed,right click >new part
Give the package name,parts per package etc
hopes this helps
Could you send me a screen capture ?
thanx
I use PADS Logic.
Thanx for your help gmh :D
in schematic, you have to create separate parts for each function like blocks and the BGA is like a hybrid part
