May 22, 2018 #1 W wjj Newbie level 4 Joined May 3, 2018 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 36 When I invoke SP parameter file to do tran simulation.Just as the picture shows,parameter is set in this way,and n2port is connected in this way.So,is there any error? any other setting needed? Thank you:grin: Last edited by a moderator: May 22, 2018
May 22, 2018 #2 pancho_hideboo Advanced Member level 5 Joined Oct 21, 2006 Messages 2,847 Helped 767 Reputation 1,536 Reaction score 733 Trophy points 1,393 Location Real Homeless Activity points 17,490 wjj said: When I invoke SP parameter file to do tran simulation. Click to expand... Show us simulator name and its version which you use. wjj said: any other setting needed? Click to expand... It depends on method for treatment S-parameter in transient analysis and frequency range and frequency resolution of S-parameter. Major treatments are convolution and rational model approximation. Also it depends on maximum frequency or fastest rise time in transient analysis. https://edadocs.software.keysight.c...leshooting+a+Transient-Convolution+Simulation https://www.edaboard.com/showthread.php?303606 Last edited: May 22, 2018
