How to do layout for resistor and capacitor using Virtuoso?
zahrein
Full Member level 2
Help on Virtuoso Layout?
Guyz, i need help on how to do a layout for resistor and capacitor using virtuoso layout?
How is the design rule ?
How is the calculation?. Thank you.
The design rule is provided by the foundry. The caculation is:
R = Rs * (W/L)
Rs is the sheet resistance.
C = C0 * W * L
C0 is the unit capacitance ( F/um²)
Re: Help on Virtuoso Layout?
You must follow the layout design rule.
You need to find out what kind of resistors/capacitors are available in your process, and then choose one based on the trade-offs such as device size, values, accuracy, etc.
R = Rs * (W/L)
C = C0 * W * L
It's right, but there are some different resistor structures,for example ,there are poly resistor ,active resistor ,metal resistor,n-well resistor and so on.The same to capacitor.It's different in different foundries.
You should follow the design rule, I think it must be very clear in the rule files that how to lay out r & c.
And sometimes, the dummy resistors and capacitors are nessencery.
ive got wat u all said.
Usually when i use cadence virtuoso layout, i just take the resistor from the instance. From there, i will change the value of the resistor by clicking the properties.
If i wanna design the resistor manually , i must know the value of Rs (sheet resistance). Where can i get the value of sheet resistance from the Cadence virtuoso layout?
You don't get sheet resistance from the Cadence. You get it from foundry. Then you use it for layout parameter extraction rules.
