You could use "create_clock -name ..." in sdc to specify a clock.
And you should also use the command "set_propagated_clock [all_clocks]"
and "remove_clock_uncertainty {*}" to specify it is NOT an ideal clock. Otherwise, Astro will treat all your clock as an ideal clock. When it exports back annotated and parasitic information in SDF, RSPF, DSPF & SPEF file, the clock latency and skew will not be included. To make things simple, you could export the sdc file from your STA environment by "write_sdf ...."
