sunjiao3
Member level 5
Hi, friends. I encountered a problem. There is a logic sigal DIS which will become an impulse by random. I wanna distill it's falling edge when this change occurs. Here, I used RS triggers. (I built them by nmos and pmos and simulated with hspice.)__master-slave RS trigger built on NAND gates which will sample the input on rising edge and output the change on falling edge and basic RS trigger built on Nor gates.
I set the 's' of RS trigger '0', and the signal DIS as the input of 'R'. Then, having passed 4 inverters, the delayed DIS is used as the input of clk. However, the Qp and Qn remained unchanged. Then, I made 2 signals, one of them is about 10us/100us delayed to compose the other signal. The output still remain unchanged. So, it seems that it not the delay time that causes such problem.
Friends, could any of one give me some suggestions? Both on plan and structure. Thank you very much!
