How to design 4bit divider circuit??
nanoYasser
Junior Member level 1
I'm here sir!
4 bit divider
Hi experts..
I have aproblem in designing an elementary calculator using logic gates IC's
There is no problem about addition,sub and multiplying
Can any one please tell me how to desing a circuit which can divid 4 bit on 4bit?
Thanks in advance..
Yassorty,
4-bit divider circuit
Hey
I think you can not divide a 4bit by 4bit without using a register. You will need one register to store the quotient value and other to store the remainder.
Ther are algorithmsfor doing so which use shifting of bits (you can find them in Computer system Organisation by Morris Mano)
tronix
divider circuits morris mano
If it is unsigned number, shift the dividend left by divider. something like this;
wire [4:0] results;
assign results = dividend << divider;
if it is signed number, then it is a bit more complicated. Do something like this;
module div(a,b,d);
input [3:0] a,b;
output [7:0] d;
reg [3:0] dvd,dvr,not_dvr;
reg [7:0] d;
reg [3:0] quo,rem;
reg sign;
integer i;
always @ ( * )
begin
if ( a[3] == 1'b1 ) // Changing the 4-bit signed to unsigned, for both, the divisor and the dividend.
dvd = ~a + 4'b1;
else
dvd = a;
if ( b[3] == 1'b1 )
dvr = ~b + 4'b1;
else
dvr = b;
not_dvr = ~dvr + 4'b1;
sign = a[3] ^ b[3]; // sign bit for the product.
if (b==4'b0) // For the case where the divisor is 0,
//we make the quo & rem both zero.
begin
quo = 1'b0;
rem = a;
end
else
begin
quo = 1'b0; // set the quotient to 0.
for ( i=1; i<=8; i=i+1) // actual division division algorithm.
if (dvd >= dvr)
begin
dvd = dvd + not_dvr;
quo = i;
end
rem = dvd;
end
if ( a[3] == 1'b1 ) // same signs
rem = ~rem + 4'b1;
if ( sign == 1'b1 ) // quotient is positive only if both the
//dividend & the divisor have the same sign.
quo = ~quo + 4'b1;
d = \{ quo, rem \}; // Concatenating to get the result.
end
endmodule
