How to create a real custom vccs like a real device
rosadellavita
Newbie level 3
Newbie level 3
Dear all
I want to design a vccs to implement this function:
I(y)<+ tanh(V(x));
I have done that using a verilogA model and I connect it in the cadence circuit which is as in the attached file, the model itself works fine but I want it to act as a real electronic component when connected to the circuit, by means when I change the output resistance the output current from this component should be changed accordingly as in the real electrical circuits, how can I do that, the current is always fixed and not affected by the resistor next to it. Because at the end I'll do a lab work by which I will use a similar component .
I read about bsource but I did not find it in any of the libraries !
any suggestion will be appreciated.
Thank you
This function can be realized with "Differential Pair" circuit.There are many information about this circuit and Barrie Gilbert ( Analog Guru ) has developed tons of circuits using with this basic one.
If you search the articles of this great man and Chris Toumazou, you'll find very interesting and chic ideas.
