How to create a new ref des in Allegro and associate it ?
renato
Brazil
allegro ref des
I had a .brd file and need to modify it to insert a connector. I change all the layout and insert a connector symbol in the board, but I can't set a ref designator to this conn and I need it to change my netlist. Could you please tell me how can I create a new ref des in Allegro and associate it with my connector symbol ?
Thanks in advance.
Renato
What about exporting the netlist from Allegro, manually edit to add your connector with the right RefDes and reimport this netlist ??
Will work...
Tobs
Re: Ref Des in Allegro
renato said:
Thanks in advance.
Renato
you CAN't..... It has to be a part of your LOGIC unless you find a way to ulter LOGIC ( netlist)
Thanks and solution
Thanks for answers ...
I export Allegro Netlist, modified and re-imported with new feature. Automatically it included new rats and clear all DRC in new component.
My other prblem was to generate a netlist ... it produce a file with error 'cause I hadn't included my lib dir in the path.
Best regards,
Renato
