How to convert lib file to db file?
vahid_roostaie
Newbie level 5
I want to construct db file from lib file. is there any special command or special method for this?
how to convert .lib to .db
Hi vahid_roostaie,
if u want to convert the lib to db. u need to have librarie compiler if u need the functionality. other wise if u need the db for the link processs like rams then u can obtain db using the design-compiler also.
read_db library.lib
list_libs
write_lib -macroname -formate db -o library.db
will give u the db in the design-compiler.
regards
rameshs
convert .lib to .db
read_db cannot read lib file, it can only read db format to read lib file you have use read_lib
read_db library.lib
list_libs
converting .db to .lib
just try this in library compiler,
read_lib x.lib
write_lib -format db x
then u can have x.db file in u r directory where u have executed the above commands. Hope this helps u.
read lib file
Just cross check that library name for reading and writting should be same.
