asking
Full Member level 5
I have one LCD Clock using DS1307 + PIC16F877A. But now i just want to use only Time and want to transfer data to 7 Segment Multiplexed 4 Display. So can anyone help me regarding changes made to the C Code ? i know about multiplexing 7 Segments using pic. i just need to transfer only time to 4 7-Segment multiplexed display..so m confused.... because output from DS1307 to the microntroller is i2C and from microcontroller its BCD....
i just need to display only time on the 7 segment display...
C Code :
C Code :
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 // LCD module connections sbit LCD_RS at RB2_bit; sbit LCD_EN at RB3_bit; sbit LCD_D4 at RB4_bit; sbit LCD_D5 at RB5_bit; sbit LCD_D6 at RB6_bit; sbit LCD_D7 at RB7_bit; sbit LCD_RS_Direction at TRISB2_bit; sbit LCD_EN_Direction at TRISB3_bit; sbit LCD_D4_Direction at TRISB4_bit; sbit LCD_D5_Direction at TRISB5_bit; sbit LCD_D6_Direction at TRISB6_bit; sbit LCD_D7_Direction at TRISB7_bit; // End LCD module connections unsigned short read_ds1307(unsigned short address) { unsigned short r_data; I2C1_Start(); I2C1_Wr(0xD0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0 I2C1_Wr(address); I2C1_Repeated_Start(); I2C1_Wr(0xD1); //0x68 followed by 1 --> 0xD1 r_data=I2C1_Rd(0); I2C1_Stop(); return(r_data); } void write_ds1307(unsigned short address,unsigned short w_data) { I2C1_Start(); // issue I2C start signal //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0 I2C1_Wr(0xD0); // send byte via I2C (device address + W) I2C1_Wr(address); // send byte (address of DS1307 location) I2C1_Wr(w_data); // send data (data to be written) I2C1_Stop(); // issue I2C stop signal } unsigned char BCD2UpperCh(unsigned char bcd) { return ((bcd >> 4) + '0'); } unsigned char BCD2LowerCh(unsigned char bcd) { return ((bcd & 0x0F) + '0'); } int Binary2BCD(int a) { int t1, t2; t1 = a%10; t1 = t1 & 0x0F; a = a/10; t2 = a%10; t2 = 0x0F & t2; t2 = t2 << 4; t2 = 0xF0 & t2; t1 = t1 | t2; return t1; } int BCD2Binary(int a) { int r,t; t = a & 0x0F; r = t; a = 0xF0 & a; t = a >> 4; t = 0x0F & t; r = t*10 + r; return r; } int second; int minute; int hour; int hr; int day; int dday; int month; int year; int ap; unsigned short set_count = 0; short set; char time[] = "00:00:00 PM"; char date[] = "00-00-00"; void main() { I2C1_Init(100000); //DS1307 I2C is running at 100KHz CMCON = 0x07; // To turn off comparators ADCON1 = 0x06; // To turn off analog to digital converters TRISA = 0x07; PORTA = 0x00; Lcd_Init(); // Initialize LCD Lcd_Cmd(_LCD_CLEAR); // Clear display Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off Lcd_out(1,1,"Time:"); Lcd_out(2,1,"Date:"); do { set = 0; if(PORTA.F0 == 0) { Delay_ms(100); if(PORTA.F0 == 0) { set_count++; if(set_count >= 7) { set_count = 0; } } } if(set_count) { if(PORTA.F1 == 0) { Delay_ms(100); if(PORTA.F1 == 0) set = 1; } if(PORTA.F2 == 0) { Delay_ms(100); if(PORTA.F2 == 0) set = -1; } if(set_count && set) { switch(set_count) { case 1: hour = BCD2Binary(hour); hour = hour + set; hour = Binary2BCD(hour); if((hour & 0x1F) >= 0x13) { hour = hour & 0b11100001; hour = hour ^ 0x20; } else if((hour & 0x1F) <= 0x00) { hour = hour | 0b00010010; hour = hour ^ 0x20; } write_ds1307(2, hour); //write hour break; case 2: minute = BCD2Binary(minute); minute = minute + set; if(minute >= 60) minute = 0; if(minute < 0) minute = 59; minute = Binary2BCD(minute); write_ds1307(1, minute); //write min break; case 3: if(abs(set)) write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator break; case 4: day = BCD2Binary(day); day = day + set; day = Binary2BCD(day); if(day >= 0x32) day = 1; if(day <= 0) day = 0x31; write_ds1307(4, day); // write date 17 break; case 5: month = BCD2Binary(month); month = month + set; month = Binary2BCD(month); if(month > 0x12) month = 1; if(month <= 0) month = 0x12; write_ds1307(5,month); // write month 6 June break; case 6: year = BCD2Binary(year); year = year + set; year = Binary2BCD(year); if(year <= -1) year = 0x99; if(year >= 0x50) year = 0; write_ds1307(6, year); // write year break; } } } second = read_ds1307(0); minute = read_ds1307(1); hour = read_ds1307(2); hr = hour & 0b00011111; ap = hour & 0b00100000; dday = read_ds1307(3); day = read_ds1307(4); month = read_ds1307(5); year = read_ds1307(6); time[0] = BCD2UpperCh(hr); time[1] = BCD2LowerCh(hr); time[3] = BCD2UpperCh(minute); time[4] = BCD2LowerCh(minute); time[6] = BCD2UpperCh(second); time[7] = BCD2LowerCh(second); date[0] = BCD2UpperCh(day); date[1] = BCD2LowerCh(day); date[3] = BCD2UpperCh(month); date[4] = BCD2LowerCh(month); date[6] = BCD2UpperCh(year); date[7] = BCD2LowerCh(year); if(ap) { time[9] = 'P'; time[10] = 'M'; } else { time[9] = 'A'; time[10] = 'M'; } Lcd_out(1, 6, time); Lcd_out(2, 6, date); Delay_ms(50); }while(1); }
