how to compile files in a library (Xilinx)
bcdeepak
Member level 5
hi
plz tell me how to go to a different (created by a user) library and compile the file in it in Xilinx
by default "work" library is opening.
for compiling different file locating in different library you have to change library .... coz we can compile only those file which are located in present library....
you can use "compxlib "to compile xilinx library.
compxlib -s <simulator> -arch <arch>
[-l <language>] [-lib <library>] [-dir <output_dir>]
[-w] [-log <log_file>] [-p <dir_path>]
[-smartmodel_setup] [-verbose]
compxlib -cfg
compxlib -info <dir_path>
compxlib -f <cmd_file>
compxlib -help
compxlib -help <value>
for more detail you can go to the web of xilinx to search for this command.
