How to change the wire nets' color in Cadence?
asic_ant
Banned
Nanjing
cadence xhange colours net
Any ideas?
Thanks in advance.
eng_Semi
Full Member level 6
Egypt
cadence change colours net schematic editor
open the LSW (Layer Selection Window) and search for a layer called "wirenet" and "wirelabel". But u must set all layers valid from the resource display editor.
mask_layout
Member level 2
display.drf schematic wire color
Hit F3, When you hit the command and see if you will have an option to change the color for mark net. It works that way for me...
asic_ant
Banned
Nanjing
cadence schematic wire color
I mean in Schematic edit envionment
Hughes
Advanced Member level 3
cadence color mark net
Edit the display resource as eng_Semi mentioned. You can access the display editor either from LSW or from icfb. You may also edit the display.drf by a text editor (e. g. vi), searching the word "wire" to find which display resoure name it uses.
mightyblack
Newbie level 2
cadence drf
In my display.drf, the wire lines are responisble by y0-9, which can not be found any info in display.drf. I was told by the infomation. Try it.
Reactions: Nadida
    Nadida
Hughes
Usually, the display resource name of wire lines is "wire". If you have changed it, you can either change the properties of the display resource it actually uses or change the display resource name of layer "wire drawing" back to "wire".
