urian
Full Member level 3
Hi,there
I am working with a 8b pipeline ADC. People said limitation of capacitor is mismatch more than thermal noise. So I want to calculate the mismatch between Cs and Cf in the MDAC with the help of foundry process files. When I checking the documents, I find the paremeters table below with regard to capacitor, and there is no more explanation.
| Mismatch |
Area of capacitor | Mean(%) | Std.dev(%) |
50um X 50um | 0.017 | 0.023 |
I wonder what the meaning they are. What value should I use, Mean or Std?
If I use two capacitors both are 50um X 50um, then the mismatch between them is 0.017% or 0.023%?
If I use two capacitors with ratio 1:2 and have unit capacitor 50um X 50um, what is the mismatch now?
Again, If I use two capacitors with ratio 1:4 and have unit capacitor 50um X 50um, what is the mismatch now?
Thanks in advance
Regards
urian
| Mismatch |
Thanks in advance
Regards
urian
